up.mi.man
- Feb 23, 2009
- Marquette MI
- 2017 sidewinder ltx se
- Marquette Mi right on trail 417
I dont think i want to tackle this job how long should it take the dealer. i already bought the wheel from them.
Thanks Dale
Thanks Dale
raginyamaha
should take them less than an hour i would think...
Grimm
Probably take more effort, time and money to have your Dealer do such a simple job.
It takes just a few minutes.
up.mi.man
- Feb 23, 2009
- Marquette MI
It's the wheel next to the front shock. it dose not look easy to me. lol
Thanks Dale
Thanks Dale
Grimm
What model sled?
up.mi.man
- Feb 23, 2009
- Marquette MI
09 nitro xtx
Grimm
Check out the diagram here:
http://partsfinder.onlinemicrofiche.com ... SY---TRACK
Unless I'm mistaken, it looks like you only have to remove one bolt to remove the wheel...2 if you have trouble and have to remove the mount.
up.mi.man
- Feb 23, 2009
- Marquette MI
I looked it over and it's not a easy job The dealer said 1 to 1.5 hours i called another dealer they told me the same said the needed to drop the back half of the skid.
Grimm
Is the idler wheel mounted on the same shaft as the shock? Then I'd understand dropping the skid.
brs077
- Mar 8, 2005
- Cobleskill, NY
- 2013 Yamaha FX Nytro XTX 1.75
THe dealer is way overthinking this.
You just take the top bolt out of the center shock, then with a little muscle pull the shock back, then you can take the bolts out of each side, and take the whole shock assembly out. Once you have the wheel replaced, just put it all back the same way.... It's an hour tops, including moving the sled into the garage, getting it up on a bench, jacking the rear up a bit and everything in reverse, and very easy.
up.mi.man
- Feb 23, 2009
- Marquette MI
I brought it to the dealer they changed both wheels and charged me 1 hour. Thanks guys for your replys.
Thanks Dale
Thanks Dale
