How to: 2011 Yamaha Apex track change Video
biffdotorg
- Dec 2, 2008
- Pelican Rapids, MN
- www.biff.org
- Apex XTX and Viper LTX SE
- www.biff.org
Thanks for the quick tip on the parking brake. I have often struggled with getting it adjusted by the cable, and can't say that I have ever looked it up in the service manual. As it seemed straight forward to adjust the cable. And it never held since. Nice tip.
I'm assuming that was an SE with rail extensions. It looked like rail extensions in the skid.
Thanks for the quick tip on the parking brake. I have often struggles with getting it adjust by the cable, and can't say that I have ever looked it up in the service manual. As it seemed straight forward to adjust the cable. And it never held since. Nice tip.
Your welcome!! Yes sir, it was a SE with extensions and Mega Float was changed out.
Bluebullet
- Mar 19, 2005
- Augusta, Maine
- Maine
Great vid Tom!
Great vid Tom!
Thank you !
03RX1-ER-LE
Bleed BLUE
- Feb 22, 2008
- 2011 Apex XTX 12,497 miles
2009 Apex ER 8,169 miles
Tow Vehicle
2021 Wolverine X4
- Livonia Michigan
Now you need to do a Apex valve adjustment video.Thank you !
on the motor?
03RX1-ER-LE
Bleed BLUE
- Feb 22, 2008
Tow Vehicle
2021 Wolverine X4
- Livonia Michigan
I know you have the one for the EXUP valve check and adjust, thought if you were bored you could do the 20 valves in the motor.
Thats no easy job.. thanks but most guys wont be able to do that.
apexrrrrrrr1
- Dec 7, 2019
- Massachusetts
- 2006 Yamaha APEX GT
2006 Ski doo 550fan
awesome video, what table do you use? would you recommend it?
Handy lift!! Love it
valve set is going to dealer on 11 at end of season.
03RX1-ER-LE
Bleed BLUE
- Feb 22, 2008
Tow Vehicle
2021 Wolverine X4
- Livonia Michigan
I got many more miles before mine would need to be done, after wrenching since the early 70s I have worked with a lot of wanabe Techs. I don't know if I could trust someone to do such an evasive repair. I will do it myself so I know it will be done right.valve set is going to dealer on 11 at end of season.
i have done it with the shim and bucket on my xt350 and that sucked even as a 1 lunger and i had shims for it. with the apex, i would have to take it apart, order the shims and then remeber how to put it back together probably a month later without being disturbed by some one........i am not that lucky.
good tips on the e brake as i never seem to get it to last when i set it.
- 146K
