1. We are no longer supporting TapaTalk as a mobile app for our sites. The TapaTalk App has many issues with speed on our server as well as security holes that leave us vulnerable to attacks and spammers.
    Dismiss Notice
How to change chaincase oil on a RS Venture?
Discussion in 'RS General Talk' started by Matfarsan, Apr 3, 2018.
  1. Matfarsan
    Matfarsan Newbie
    8
    Kalix
    Country:
    Sweden
    Snowmobile:
    Yamaha Venture RS
    Ive bought an -09 RS Venture TF and the last owner didnt know when the chaincase oil last was changed so I guess I better do it now when this season is over.
    But I cant find the oilplug for the chaincase (just the plug to change motor oil, wich I also will change).
    Where will this plug sit or do you use an oilpump to drain the old oil?
  2.
  3. Roger
    Roger Expert
    277
    Osgoode Ontario Canada
    Country:
    Canada
    Snowmobile:
    2012 RS Venture GT (power steering doesn't work when real cold)
    2006 Indy 500
    The drain plug is inside the tunnel. I forget if you need a wrench, or Allen Key to get the plug out.
    Matfarsan likes this.
  4. TrueBlue
    TrueBlue Lifetime Member Lifetime VIP Member VIP Member
    419
    Franklin Park, IL
    Wrench will work. Bolt is right behind chain case inside of tunnel.
  5. Matfarsan
    Matfarsan Newbie
    8
    Kalix
    Country:
    Sweden
    Snowmobile:
    Yamaha Venture RS
    Thanks for your help.
    I will try to locate the plug.
  6. Winderallday!
    Winderallday! VIP Member VIP Member
    576
    SW, Ontario
    Country:
    Canada
    Snowmobile:
    2018 Sidewinder DX
    Chaincase: 12mm wrench up inside tunnel right at bottom of chaincase. 250ml to get the proper amount in chaincase.
    Also, there are two drain plugs for the engine oil, one on bottom of motor accessible by removing the access cover, and one on oil tank (reservoir) on right hand side of sled next to chaincase/brake rotor. Plug is on bottom of tank.
    Fill with new oil and check level in the tank without threading the dipstick into the tank.
    Cheers.
    Redbeard likes this.
  7. Matfarsan
    Matfarsan Newbie
    8
    Kalix
    Country:
    Sweden
    Snowmobile:
    Yamaha Venture RS
    It worked like a charm
    Both motor and chaincase oil changed today.
    Thanks for the help.
Share This Page
  1. This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
    Dismiss Notice
