rgextreme1998
I want to change the oil and filter. Do i just take the cover off the airbox and then pull the boots off the carbs or pull the box off the boots? I know, silly question! thanks in advance.
- Mar 1, 2004
Please take a minute and add your LOCATION to your Profile, as this is a SITE REQUIREMENT
TK's 4 UR Co OPERATION
BTW....Not a silly question @ all, everyone has gone through this @ one time or another. New models keep coming out with a twist on how to get those ones off.
HERE U GO
HERE U GO
rgextreme1998
Ok, got the profile updated, thanks for the links.
I went thru but didn't really see an answer. People just say pull the airbox off. I assume the boots on the carbs are attached to the airbox itself and it comes off as one piece? I just don't want to tear it apart and break it. Thanks again, rg
maxdlx
- Feb 27, 2004
- Tipton, Iowa
- 07 Apex RTX
the boots come off of the carbs and stay with the air box. You loosen the clamps on the boots at the carbs, and it will come right off. Maxdlx
RedRocket
Loosen the clamps around the carb boots with a phillips screwdriver and remove the rubber hose that runs underneath the air box. I think there was a rubber strap in the front as well, been a while since I put it in storage.
rgextreme1998
Great! Thanks a lot, fellas.
