yamahacat69
Hi any idea how much boost I should be seeing with the 325 header tune thanks
sledding rocks
20lbs boost 300hp , not sure on 325
HURRICANE
The hurricane 325hp tune runs at 24lbs boost. It’s safe to run at wot with a stock engine on 94 octane fuel. We have now spent the winter testing and tweaking it. It looks like it’s perfect at this time
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
Wow nice work Dave....this is some serious big time power!The hurricane 325hp tune runs at 24lbs boost. It’s safe to run at wot with a stock engine on 94 octane fuel. We have now spent the winter testing and tweaking it. It looks like it’s perfect at this time
Dan
Blue shadow
What have you done for the 325 tune and any vids to go with it ,thanksWow nice work Dave....this is some serious big time power!
Dan
Correct me if I'm wrong Dave. That would be Total boost control, Header, 1000cc injectors, Bigger fuel pump + regulator and 4Bar Sensor.
cjr
- Jan 28, 2018
- Old Forge
- 2018 Sidewinder 2021 sidewinder xtx le 146
Does anybody know what you need to run the 325 kit
Uhmmmm? The post before yours......
yamahacat69
Header
Fuel pump
Injectors
3/4 bar map sensor
Tune
Clutching
Cold air intake
Muffler
Some sort of boost controller example total boost controller
Fuel pump
Injectors
3/4 bar map sensor
Tune
Clutching
Cold air intake
Muffler
cjr
- Jan 28, 2018
- Old Forge
Thanks for the speedy reply I guess I’ll stick with 300 for rest of year thanks again
I would be curious to see what adjustments the fuel multiplier made with this tune on the very cold days of this winter. Anybody have data logs of this? PM me if you don't want it public
NYTurbo
I would be curious to see what adjustments the fuel multiplier made with this tune on the very cold days of this winter. Anybody have data logs of this? PM me if you don't want it public[/QUOTE
Did you see the hardware requirement a couple posts above ?
Crossfire12
- Feb 13, 2017
- New York Adirondacks
- Sacandaga reservoir
You are the public just call him on phone if your not the public.I would be curious to see what adjustments the fuel multiplier made with this tune on the very cold days of this winter. Anybody have data logs of this? PM me if you don't want it public
NYTurbo
You need big injectors as stated above. The same injectors we run 500hp on so not sure what fuel multiplier your looking to see.
You are correct, i could have worded that better, But you know what i mean. "everybody"You are the public just call him on phone if your not the public.
