Hello looking for some advice. Got the Dalton dtya 70 clutch setup. Tune is 225/240ss/270ss. See it comes with 4 set screws for each weight. Very confused to what I'm supposed to use. Thanks
KnappAttack
- Feb 19, 2004
- Welch MN
- 2023 Sidewinder LTX-LE
2017 Sidewinder LTX-LE
What tune are you going to run? Clutch weight is dependent on a bunch of parameters like HP being used, front spring, roller diameter, helix, secondary spring, secondary roller brand being used, the belt also has a huge effect on weight.
No way to tell you what to use unless we know some of the parameters you are working with, and you will still need to fine tune the weight for each machine because each one has a different attitude.
I got the answer from Dave. Thank you. However my belt is not sitting right and it only has 800 miles
About 1/16 below
