It’s now been 3 years since Hurricane Performance created the knock detection and protection system in conjunction with gap engineers while tested by TD. There have been many cases where the knock light will flash while fuelled with the correct octane for the Hurricane flash. Rather then lowering the Hurricane knock sensitivity to put the knock light out as well as lowering the engine protection, we have worked with many of Hurricane dealers and customers to find there individual issue.
Now we have had enough history to establish a trend in the cause of many premature Hurricane knock cases . It’s ALWAYS boost leaks! They can be hard to find. The trend that we are seeing though is that the throttle body boots are leaking on many sleds. This leak often takes up to 24lbs pressure applied to the induction system to diagnose. While the stock clamps are tight, they need to be modified to allow an additional tightening.
We are recommending to all 998 sled owners to tighten the clamps beyond the oem limit.
Thanks for posting Dave. You just confirmed my suspicion of a boost leak. Been seeing my boost pressure spike/dip lately even after tightening all the hose clamps. Possibly a break in the charge tubes somewhere.
Any particular side of the throttle bodies, or both?
RAMSOMAIR
How do you modify the stock clamps??It’s now been 3 years since Hurricane Performance created the knock detection and protection system in conjunction with gap engineers while tested by TD. There have been many cases where the knock light will flash while fuelled with the correct octane for the Hurricane flash. Rather then lowering the Hurricane knock sensitivity to put the knock light out as well as lowering the engine protection, we have worked with many of Hurricane dealers and customers to find there individual issue.
DMCTurbo
- Nov 12, 2005
- Val Caron, Ontario
- 2017 Sidewinder XTX LE 137
How does a boost leak cause knock?
NYTurbo
The clamps on the other side of throttle bodies have a stopper so they only tighten so muchHow do you modify the stock clamps??
Ok, so I assume the stopper needs to be shorted to allow more tightening.The clamps on the other side of throttle bodies have a stopper so they only tighten so much
RAMSOMAIR
Gotcha. Of course, the hardest ones to get to!
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
I just got off the phone with Dave to get more info!!How does a boost leak cause knock?
He is talking about the clamps on the back side of the throttle body!!
You need to remove the clamp and shave about 1/16" of the stopper to allow the clamps to tighten up more!!!
From what I understand what happens is if a leak is in this area the turbo will spin faster to keep pressures at par with the tune requirements and will cause knock!
JayM
- Oct 29, 2018
- Pickering, ON
- 2017 Sidewinder R-TX SE
Darn, I will have to look at that now!
ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
2015 Viper 270 hurricane,
- Wisconsin
More air, more turbo speed, more heat.How does a boost leak cause knock?
actionjack
- Apr 9, 2005
- Westminster, Maryland
- www.inspectorjack.com
- 2017 SideWinder LTX-LE
showtime
- Sep 16, 2016
- New Brunswick
- 09 turbo cat
12 i feel
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
12
The spacer in the #12 clamp.
