Carpet Guy
Just installed the 240-270 stock muffler flash with the dalton clutch weights but I would like to come out of the hole quicker any thoughtsand is a map sensor neccessary
race24x
Watching
Anti-lag
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
Are we talking trail sled for corner to corner I assume?Just installed the 240-270 stock muffler flash with the dalton clutch weights but I would like to come out of the hole quicker any thoughts
What are your top RPMS on the 270map?
Do you have Daltons weights? You may want to remove some weight, to rev this map higher.
Dan
Crossfire12
- Feb 13, 2017
- New York Adirondacks
- 2010 Z1 Turbo ,2017 zr9000, F1100 turbo, 700 srx
- Sacandaga reservoir
Helix?
DooZ
Studs...long ones and lots of them lol
Carpet Guy
Well I am supposed to be around 8800 but since I just did the tune I have not yet had a chance to top it off with the snow meltAre we talking trail sled for corner to corner I assume?
Dan
stevewithOCD
Yamaha, Make me Come Back
- Jan 1, 2008
- Live CT Ride MAINE
- 900 R
2006 Apex RTX
Let's back up one step.
The following questions need to be answered before anybody can help.
1. track length?
2. studs?
3. trail set up?
4. what other clutching components have been installed?
5. what year is this Winder so we know what stock components are in there
6. do you mean "out of the hole" like drag racing from a stop or like Danno is asking about corner to corner snap?
BTW: WELCOME Josh!
1. track length?
2. studs?
3. trail set up?
BTW: WELCOME Josh!
Carpet Guy
StockHelix?
137 track 144 studs stock muffler tune and 2018 rtx and dalton clutch weights and trail riding 90% but like to drag a little against friends
1. track length?
2. studs?
3. trail set up?
BTW: WELCOME Josh!
Carpet Guy
2018 137rtx with 144 studs stock muffler tune with dalton clutch weights and 90% of trail riding but like to drag buddy's with different types of tunesLet's back up one step.
1. track length?
2. studs?
3. trail set up?
BTW: WELCOME Josh!
A
Anti-lag2018 137rtx with 144 studs stock muffler tune with dalton clutch weights and 90% of trail riding but like to drag buddy's with different types of tunes
lilrez
Type and length of studs.
JPS
- Aug 23, 2014
- Clarks Summit, Pa
- 2018 sidewinder XTX, 2017 Viper XTX, 07 apex attack, 95 Vmax4
Before you make any changes you have to at least ride it with the new flash more than just around the yard.Well I am supposed to be around 8800 but since I just did the tune I have not yet had a chance to top it off with the snow melt
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
Dan
You cannot just expect the sled to be setup right automatically. I spent several days setting up my clutches after I flashed her. I tested several different RPMs for MY STYLE RIDING. I ended up a fair but different then most told me to be at.
When you run a jukebox setup of more then one MAP, you need to make some decisions. First being which map do you expect to run mostly. I run my 270 map 99% of the time, so I set things up for that primarily.
I found that for instant snap, corner to corner(which it seems like you are looking for) the best setup is revving the 270 map higher then most will tell you. This allows the 240 map to be still quite useful.
So you need to go out, put in some good fuel so you do not get any knock lite within 1000ft at least. Need a road or lake preferably with space. I'll assume you dont have data logging, so you need to watch the tach running WOT and see where she is revving on top. Lighten up your weights, to make sled rev 9 to 9100 on 270 map. This should have the 240 map revving around 8600-8700 on top then. This will make the 270 map a complete animal corner to corner with snap that will hit hard. If you rev the 270 map at 8800 only, the 240 map becomes pointless to use, and at 8800 the 270 map will not have the corner to corner snap down at very bottom.
If you still dont have snap...then it may be you need a CAI. And if still you feel its not there, then you may need a performance muffler and corresponding tunes.
Dan
stevewithOCD
- Jan 1, 2008
- 900 R
2006 Apex RTX
Josh, i believe FLEECER helped WINTERWOLF with your same set up.
I'll see if they will chime in.
That will get you close.
