fourndog
Has anyone tried the hyfax extender wheel spacer kit by Pioneer Performance? Do they work well?
sobfrogg
I just installed them on my Attak.
Looks like they will do the trick. The hyfax is about 1/8" above the counter top. The suspension rolls on the wheels.
For installing them the stock Yami boggie wheels bolt right on. The Accessorie Wheels. The Blue ones. I had to grind a bit of the aluminum off the mounts. The bearing window is smaller so the mounts would not fit the wheel.
Other than a little mod for the mod a VERY nice addition. I have also added the Front wheels that mount inbetween the rails from Fix. The only thing I am waiting on are the 8" wheels frm Richie and the offset axle. That should eliminate all hyfax rub
schroon
- Mar 8, 2006
- Schroon lake, NY
- www.pacific-custom.com
I put them on my Apex and Vector. Works great.
70superbee
I also put them on my 06 attak when I had the original wheels and all of them came apart in 30 miles. Went back and got new ones from my dealer and they lasted all last winter only 1500 miles.Plus I installed wheel kit from Fix in the front between the rails this fall so far they are working ok.
Rich
Rich
