basic700
- Mar 5, 2010
- Norwalk WI
- 2018 Sidewinder STX DX 146
2015 SRViper XTX LE
2009 Nytro XTX
My brother picked up a 2023 xtx LE, it has the 146x 1.5 track from Camso that the lugs are pre drilled, (for pre studs) I have a gun to insert actuall tire studs but camso wont / can’t tell me stud size. Other option would be to put I-grips in the pre drilled holes. Any body have info for me??
KnappAttack
- Feb 19, 2004
- Welch MN
- 2023 Sidewinder LTX-LE
2017 Sidewinder LTX-LE
How about measuring the depth of the pre-drilled holes?
fxnytrortxkid
- Apr 19, 2007
- Rensselaer, ny
- 09 nytro rtx
Personally I would just get studs tho
Arc21981
- Jan 31, 2019
- Portland,Maine
- 2018 Sidewinder xtx se 137"
twyztid
- Feb 14, 2011
- Middleville, MI
- 2025 Sidewinder LTX LE EPS
2017 Sidewinder LTX SE
2012 Apex XTX
2012 RS Vector LTX
- Middleville, MI
I doubt the track is setup to receive studs like those for cars. Snow tires for cars have a "pocket" at the bottom of the hole for the head of that type of stud.My brother picked up a 2023 xtx LE, it has the 146x 1.5 track from Camso that the lugs are pre drilled, (for pre studs) I have a gun to insert actuall tire studs but camso wont / can’t tell me stud size. Other option would be to put I-grips in the pre drilled holes. Any body have info for me??
super1c
Moderator
- Apr 10, 2010
- Freeland - Otsego lake, MI
- 22 sidewinder LTX-LE
I grips! Email them and they will tell you the exact stud to get. I grips have been perfect for me.
Teamblue4
- Feb 20, 2008
- Il.
- 2012 Apex XTX
2013 Apex SE
2014 Apex SE
2014 Apex XTX
2016 Apex XTX
Bergstrom Skegs also has screw in carbide tip studs.
Fast
- Sep 25, 2018
Call Patrick from Igrips, he will set you up with the proper length, i think mine were15mm body and 5mm carbide. Put 200-250 in you won't be disappointed.My brother picked up a 2023 xtx LE, it has the 146x 1.5 track from Camso that the lugs are pre drilled, (for pre studs) I have a gun to insert actuall tire studs but camso wont / can’t tell me stud size. Other option would be to put I-grips in the pre drilled holes. Any body have info for me??
Patrick Lemay 4187281250
basic700
- Mar 5, 2010
- Norwalk WI
2015 SRViper XTX LE
2009 Nytro XTX
Thanks for the replies. Upon further investigation, went on I grip’s website on the computer instead of cell phone and was way more user friendly and it says on there what studs to order for his exact predrilled track. Ordered them this morning. There is only 110 predrilled holes I believe. Being it’s a 1.6 x 146 I think that will be enough traction for slowing down on the slippery corners. Thanks again, do ya snow dance.
Fast
- Sep 25, 2018
You can add more just use 1/16 drill bitThanks for the replies. Upon further investigation, went on I grip’s website on the computer instead of cell phone and was way more user friendly and it says on there what studs to order for his exact predrilled track. Ordered them this morning. There is only 110 predrilled holes I believe. Being it’s a 1.6 x 146 I think that will be enough traction for slowing down on the slippery corners. Thanks again, do ya snow dance.
- 6K
