BoondockerNytro
- Jan 20, 2009
Couple questions here...
They only make this track for doos I guess, but its a single ply 120" 2.86 pitch, 1.6 lug prestudded. So can I fit this in the nytro? Clear the exchanger? With the 2.86 extros? Also will the shorter 120" track stuff in there with smaller drivers?
terez
Yep...will fit and work well. U might have to remove the oem tunnel protectors tho.
Should work with the oem drivers.
Is it all clipped and all open window?
Does yer sled have extroverts?
Would make an excellent combo with extrovert drivers.
BoondockerNytro
- Jan 20, 2009
No it will not work with Orem drivers, the track is 2.86 pitch.
Who sells 2.86 pitch drivers for the Yamaha?
And would I have to go to 7 tooth extroverts to clear the 1.6 lug?
BoondockerNytro
- Jan 20, 2009
Ok so I orded the drivers from wahl bros. the 7 tooth drivers are the same diameter as the 8 tooth in 2.52 pitch. So nobody knows if it will clear? I know the 1.75 requires the tunnel protectors to be removed. And my buddy has a 1.5 with studs and the protectors in, will the 1.6 fit?
canoehead
- Jan 14, 2011
- NE, Alberta
- 2014 XF9000, 2016 Viper XTX
The 1.6 will clear no problem.
BoondockerNytro
- Jan 20, 2009
Ok good to hear, purchasing tomorrow
toyota4runner
- Jan 23, 2012
- Manitoba
- '09 FX Nytro
If everything works out, that's gonna be an awesome track. Make sure to post some pics
terez
BoondockerNytro said:No it will not work with Orem drivers, the track is 2.86 pitch.
My 2013 Nytro uses 2.86 extrovert drivers oem.
Plenty of choices avail aftermarket too.
I was referring to the lug height. I assumed the OP had researched the pitch/driver/track compatibility with his sled.
