Idea for '07
2BLUE4U
Zumbrota, MN
As I was sitting on my new Attak. I remembered some of you wondering about being able to see the gauges. I'm 6'2" 220lbs. I can see the gauges perfect but for next year I thought they could make the gauge cluster adjustable...either up and down or just be able to tilt it to a different angle. I plan on putting a mountain strap on and I think that might hide the gauge a little bit.
:Rockon: Hey, I've got an idea for '07. Put that electric rising windshield on the sleds they are using on their bikes. Just use your toggle switch and go from short shield to a taller one.
Why not scrap the guages all together and go with a heads up display on the windshield/visor/goggles? :D
Here is an idea integrate the gauge pod into the handle bars and add GPS to it. If it can be put on a watercraft why not a sled.
You are all over this site today.....lots of spare time???
I do like the idea of GPS..... :moon: :moon:
Look whos talking paulrxwarrior. Don't you need to go pick up your sleds? I figured you would like the idea of GPS. ;)!
How about communicators that are built into the sleds! (like cat)
an ACURATE speedo!
Do something like polaris did on there 05 fusion gage cluster,it is not as preety as my yammi,but it is much more funtional,you can toggle back and forth between analog or digital,its nice to know what your rpms are precisely not guess at them same thing for speed you can have analog or digital,plus both rpm and speed have max recall,that neat and on the 50th i got the altimiter and outside air temp gage,so yamaha see if you guys can add some of these features to 07 and beyond... :Rockon:
