North Bay Ned 691
Hello,
Was just out on the lake with my 2016 VK and my buddy stopped me and said my front Idler wheels were not spinning on either side. I just had dealer install Dupont slides and was wondering if that might be the reason. The two front Idler wheels on both sides are not making contact with the track. Any ideas or comments would be welcomed. Thanks
they might not contact until the slides wear in a bit. might have to put some oversize ilders there if you do not want to wait for it to wear in.
North Bay Ned 691
Do you know what size I would put on?they might not contact until the slides wear in a bit. might have to put some oversize ilders there if you do not want to wait for it to wear in.
North Bay Ned 691
Thanksthey might not contact until the slides wear in a bit. might have to put some oversize ilders there if you do not want to wait for it to wear in.
There is a kimpex oversized wheel that is 5.32. Stock are 5.13 I think. It is a direct replacement for the stock apex wheels. If your bearings are the same it should bolt right on.
North Bay Ned 691
Thanks again.There is a kimpex oversized wheel that is 5.32. Stock are 5.13 I think. It is a direct replacement for the stock apex wheels. If your bearings are the same it should bolt right on.
