Ruggybuggy
- Sep 1, 2013
- Kenora, NWOnt, Canada
- 2007 Phazer FX 144
Everyone on this forum says you can run 87 fuel but I have a label on the machine by the gas cap that says 91 or higher.
- Nov 1, 2009
- Winnipeg, Manitoba
- 2009 Phazer RTX
you can get away with 87. I prefer to run 91 but thats just my opinion
RIGIDONE
Only ever ran 91 or better in the phazer, I thought my sticker on the sled said 89 or better, my nytro says 87, but I was running 91 to stay away from ethanol, but I had to get 87 once, and whoa!!! what a difference,..nytro runs way better on 87, I do use an ethanol treatment..so no worries..but yea, its a noticeable seat of the pants difference..i never put anything below 91 in my phazer though..
iwant1
87 octane fuel is up to 10% ethanol, moisture collecting and separating fuel. The phazer has a high compression engine and it requires the better (higher octane) fuel to avoid detonation. Im not sure about the 3 cyl Nytro engine's compression ratio but it does not rev as high as the phazer. I had to use 87 octane once and it was a noticeable performance loss. stick with the premium fuel its only a couple bucks per tank
Gone Blue
- Oct 11, 2006
- Howell, Michigan
I prefer to run 91 and above. I have added 87 when that was all the gas station had. Since the Phazer is designed to run on premium it will make the most hp and get the best gas mileage with 91 and above. There a few on here that prefer to always run regular. Their choice, not mine.
G.B.
G.B.
- Nov 1, 2009
- 2009 Phazer RTX
Not all 91 is ethanol free.
If you need gas and you are in a pinch you can run 87. If there is any pre ignition the knock sensor will detect it.
Trucker
- Aug 19, 2009
- Lafayette,Indiana
- www.fultzracing.com
2016 SR Viper S-TX 146 DX
2009 Phazer GT
1985 Phazer E
I always run Premium gas 91 octane. it holds up better than the cheap stuff. Plus around here it doesn't have Ethanol.
couch
Have always run regular (87) with no fuel issues to date - approximately 17000 km between the various phazers in the shed.
Mooseman
- Nov 3, 2009
- Greely, Ontario
'07 Venture MP (gone)
'07 Phazer FX (gone)
'09 Phazer GT (gone)
'10 Nytro FX (son's)
- Greely, ON Canada
Here's another fly in the ointment. Later years apparently say to use 87 octane Even then I would still use 91 just to avoid the ethanol. And the manual says that if you have to use a lower "quality" fuel, the knock sensor will take care of any knocking.
Petro Canada uses ethanol in all their grades.
Ruggybuggy
- Sep 1, 2013
Mooseman said:Here's another fly in the ointment. Later years apparently say to use 87 octane Even then I would still use 91 just to avoid the ethanol. And the manual says that if you have to use a lower "quality" fuel, the knock sensor will take care of any knocking.
So did they change anything mechanically with the motors?
Buy gas from Canadian Tire Gas bars, they use no ethanol so my boat, sled and FZ1 all get it.
porkchop
Dave,
Your motor will run on any octane
Black7
- Mar 23, 2013
- Michigan
2015 SR Viper X-TX
2016 SR Viper S-TX 137 DX
My 2013 still shows to run 91 octane.
blueironranger
- Feb 3, 2009
- Iron Range MN
2014 Viper XTX
2009 Phazer MTX
Mostly 87 unless 91 non-ethonal is with in .30 or so. There are a lot of stations charging 1.00$ + for non ethy 91 over 87! I've noticed no difference in powers and have NEVER seen the DCS light come on due to bad/low octane gas.
MikeWalters
I always run 91 because at Shell and Co-op gas stations that is the one without ethanol. For how many tanks a season I go through really it doesnt affect anything cash wise, so I go with prem.
Jeffz
- Feb 3, 2010
- Cresco, Iowa
2008 Yamaha Nytro RTX 40th
2007 Phazer "RTX"
Would anyone recommend E10? We've had a lot of people filling up with it at the gas co-op here and haven't heard any complaints yet.
- 6K
