Qc Flatlander
Actually I run an external fuel pump (Walbro GSL-392) on SC Apex;
I want to replace it with an In-Tank High Flow Fuel Pump (min. 255LPH); Does anyone tried to fix something instead of the OEM pump on the thank and Is there something exist that is bolt-on on the market ?
		kinger
- Jan 17, 2005
- Clear Lake, IA
- www.piergenius.com
I run a walboro 255 lph fitted to the stock fuel pump assembly modified to work.  I posted a how to if you search unde rmy name in the garage thread.
		kinger
- Jan 17, 2005
- Clear Lake, IA
here is the thread good picts from speed and myself
http://www.ty4stroke.com/viewtopic.php?t=84235&start=15
Qc Flatlander
Thanks for the pics and the link..........really appreciate.
		kinger
- Jan 17, 2005
- Clear Lake, IA
OH I FORGOT, this really ticked me off last year the stock fuel pump has a 10 amp fuse and it blew on a trip and I forgot there was a fuse down by the battery area it must be replaced with a 20 amp fuse then all is fine.
My stock 10 amp lasted about 300 miles before it blew and I was totally confused. Got on here and everyone said oh yeah replace the fuse with a larger one. The wiring and everything will take it.
My sled holds what ever A/F ratio I set it at now. Good luck
