Matthew457
Who has put this same can on their nytro? It’s smaller profile than the ultra q so I’m just wondering if someone has put this exact can on the nytro and how to do so. Just how the super q attaches to the sled, cause this can is a different shape than stock so just wanna know if it slides right into place and that’s it or if there is more to it. Thanks! Picture included so let me know if you got the exact one!
Pmtg04
Because it's a slip-on, it'll be a straightforward install and pretty much identical to any other slip-on install. Here's a video of an equivalent install...
Matthew457
Ah okay, comes with a bracket to fasten it? That’s about it?Because it's a slip-on, it'll be a straightforward install and pretty much identical to any other slip-on install. Here's a video of an equivalent install...
Dr. FeeLGooD
12 horse? Is that everything else stock?
Matthew457
Not sure, I’m getting the super q, not the barker.12 horse? Is that everything else stock?
Seavey82
You may want to replace the donuts with copper since you will have the seat off and exhaust plate. Ulmer sells them, OFT, and others. Many forums on this, mine were simple to change others not so much. But it's a necessity. Also your stressing; everything is plug and play and will fit with oem. Also, no slip on will give you 15hp. Maybe 2 to3 hp that you will never notice. Cans are for sound change only.
Dr. FeeLGooD
I agree, but buddy in the video says its a 12hp gain.Also, no slip on will give you 15hp. Maybe 2 to3 hp that you will never notice. Cans are for sound change only.
Matthew457
thanks man, prolly just gonna throw the can on, gotta take off the gas tank to get the exhaust donuts changed so I’m just gonna leave it, other Yamaha I owned had 16 thousand km on it with out changing donuts ever, just gonna leave itYou may want to replace the donuts with copper since you will have the seat off and exhaust plate. Ulmer sells them, OFT, and others. Many forums on this, mine were simple to change others not so much. But it's a necessity. Also your stressing; everything is plug and play and will fit with oem. Also, no slip on will give you 15hp. Maybe 2 to3 hp that you will never notice. Cans are for sound change only.
