andyroo
Hi everyone
I’m going to install some new OEM hand warmers and the kit comes with the warmer, hand grips and 4 rivets.
Is there supposed to be glue that comes with the kit.
Or because of the rivets, Yamaha doesn’t use any glue?
Let me know if I should get some grip glue or not bother
RobX-1
- Coldwater, OH
Most just use some cheap hairspray to spray inside the hand grip for adhesion vs using some sort of glue. You will be surprise at how well it will hold once dried and riveted in place.
biffdotorg
- Dec 2, 2008
- Pelican Rapids, MN
- www.biff.org
- Apex XTX and Viper LTX SE
- www.biff.org
This is the way. Hairspray lubricates when going on, but dries like light glue. Used it a few times and has worked always (except on that damn roto-tiller)Most just use some cheap hairspray to spray inside the hand grip for adhesion vs using some sort of glue. You will be surprise at how well it will hold once dried and riveted in place.
Fast Lane
- Feb 6, 2020
- Winnipeg
- 2007 Yamaha Nytro ER
- Winnipeg
I used Gorilla glue epoxy.
JustJoe
- Dec 4, 2023
- Connecticut
- 2008 Yamaha Nytro FX
I've read filling the handlebars with foam helps, has anyone done this? Is it as simple as getting spray foam and loading them up?
yes foaming the bars does help the handwarmers get hotter.
andyroo
I agree with the foam.
I had them on high and I had to turn them down.
