why do I have hard time putting my skis back on my mtx or is it just me or is there a trick gettting bolt lined up. tried puch get bolt through intil it has to thru otter saddle
its you..lol, some of them can be a pane. Are they stock skis or aftermarket?
karl
- Dec 9, 2007
- Whitehorse, Yukon Territory
- 2015 Phazer XTX
I was moving my skis to a new stance and found the rubbers hard to compress enough to get the bolts all the way through on stock skis. got the bolt through to the inside and then used a c-clamp to pull the ski up and compress the rubber enough to get the alinement. I found it challenging.
I jack the sled up and drop the full wait of the sled on the ski, and us a big Phillips screw driver to align them and then use the bolt from the opposite way to push out the screw driver.
c and a skis
c and a skis
I understand, try my method above. Those skis, and curve rubbers are really hard and can be a bare.
thanks for advice will try your idea
karl
- Dec 9, 2007
- 2015 Phazer XTX
I tried with a pin punch like you used the phillips, the rubbers were hard as a rock as I'm working outside. warmed up the rubbers buy the wood stove and that helped some.
Ya, if they are froze or super cold, I would say you will have trouble.
got skis on today used phillips and big clamp to pull everything into place weight of sled helps let lift down. changed track 6000 miles riding 153 2.6 in north dakota plus mountains kind of torn up . been a good sled after it blew up and yamaha put new engine in at 123 miles too much boost . did find large bolt holding a arm half ways out and nut gone . did have a little kink on one of the upper arms so i installed after market front end that was laying in the corner for about 4 years. see how that works out . also changed upper gear had a little play
thanks for advice on ski think
Your welcome!
