Since 2011 or so these machines came with power steering. I know Yamaha sells these front storage bags for these machines but with the added equipment in the nose compartment is this going to create any problems with the cooling of these parts. Does anything need to be done so that there is not a problem.
Rich
Rich
02ViperMody44
- Jan 26, 2009
- Utica, NY
2013 Yamaha XTX
- Old Forge, NY
- YAHOO
- ramody44@yahoo.com
I have the nose bag on my 2013, with mini jumper cables and tow straps. Never had an issue with over 9500 miles. Might want to put some black tape on one of the bracket corners so to help prevent puncturing the bag. You will know what bracket when you look in there.
Agman 57
- Dec 28, 2006
- Fostoria, Ohio
- 2018 Apex XTX LE, 50th Ann.
2018 Sidewinder LTX LE, 50th Ann.
2017 Sidewinder BTX LE
1992 V-Max 4 (Modded)
2002 ZR 120 G-daughter's
Had nose bags in my 2011’s since new with no issues
yamadoo
- Jun 3, 2003
10 Vector LTX Blue 9kmiles
11 Venture GT 4k miles
86 SnoScoot(2) for grand kids
Good to hear as I was looking at putting the old Apex nose bag in and wondered about those cooling units. I will be putting it in thanks guysHad nose bags in my 2011’s since new with no issues
biffdotorg
- Dec 2, 2008
- Pelican Rapids, MN
- www.biff.org
- Apex XTX and Viper LTX SE
- www.biff.org
Yup, I pulled my nose bag from my 2007 and dropped it right into the 2012. If you don't see the sharp edges, your fingers will find it the first time you try to stuff your full bag in there. Its the perfect place for the items you have with, but hardly ever use. (jumper cables, tow rope, fuses, relays etc)
Good luck!
Good luck!
Winderallday!
- Dec 4, 2007
- SW, Ontario
- 2018 Sidewinder DX
The knucklebusting OEM bracket and stud arrangement to retain the electrical module seemed overkill imo, not sure what Yam was thinking there.
I made up a simple aluminum strap up and re-used the original rubber bumper to create more room and less chance of damaging items in the front (beers) etc.
I stuffed the jumper cables below the clear plastic pouch into the front of the bulkhead as well, little awkward to get at, but how many times do you need jumper cables vs a beer?
Cheers guys!
Cheers guys!
02ViperMody44
- Jan 26, 2009
- Utica, NY
2013 Yamaha XTX
- Old Forge, NY
- YAHOO
Nice job on the strap
yamadoo
- Jun 3, 2003
Just installed -did Gorilla tape over sharp edges and threaded posts. Thanks again guys
Cheers guys!
Good idea, going to make 1 of these ,thank's for the pictures. I love this site
sgauthier
- Mar 5, 2009
- southwest, Ontario
- 2011 Apex XTX
I never covered anything under my bag in my 2011. Never had an issue, just make sure it's packed good and tight and it shouldn't move around much to do any damage to the bag.
- 11K
