kinger
Anybody have a good source on some that are beefy and can take re-use? Thanks
dirk_03
clamps
Try mcmaster.com. Should have some stainless clamps with constant tension spring washers.
FLYBYU
turbo addiction
http://turboaddictionparts.com/catalog/ ... cts_id=328
kinger
The tap ones are the ones I have now and I have wrecked a couple of them and had one fall apart.
I suppose I can go with them again just need to leave the IC on LOL
kinger
Anybody use a different clamp that works well?
07STI_Matt
T-bolt clamps are the way to go. Are yours blowing off or stripping out?
kinger
Not blowing off just stripping out and overall not very durable. I have had the IC off a total of 3 times and they were shot. Maybe I tighten them to hard I really put it to it when I do tighten them.
I dont think T bolt clamps fit between the TB's do they?
FLYBYU
I just ended up buying a ratchet strap
gouldsjett1
clamps
I installed turnbuckles from I/C to deltabox. No need to overtighten clamps, this way and the I/C can't pop off.
mulot30th
- Jul 7, 2007
- youtube.com
- 2023 thundercat
apex mountain crracing 174
apex blower 136 for asphalt racing
osp drag race sled (apex engine based)
I just install brackets on cylinder head (both sides) and then weld hooks on each sides of IC then use exhaust springs to keep the IC/TB assy nicely preloaded to intake ports.
givemeaboost
- Dec 5, 2003
- Great Falls, MT.
- 03 Rx1 Turbo
- Great Falls,MT
That's what I did too. I used to have the intercooler blow off at 15# and now it has held at 22-25# without any problems. Ken....FLYBYU said:I just ended up buying a ratchet strap
givemeaboost said:That's what I did too. I used to have the intercooler blow off at 15# and now it has held at 22-25# without any problems. Ken....FLYBYU said:I just ended up buying a ratchet strap
Sounds interesting....gotta pic of it?
TK's
08Nytro144
T-Bolts are the best way to go without spending a ton.
FLYBYU
