DANX123
working away in the summer. doing some changes.
replacing my ripsaw 1.25 from my attack and installing a 1 .25 camoplast 6 pitch all widows open track. everyone seems to feel the skidoo
drivers are the best. what is the part no? does any one know> are they a 9 tooh or 10 tooth? as mentioned its for an attak.
also have purchased a set of trik skis? any feedback?
i got a great deal on fox floats at port yamaha. $550 a set with pump.
any info or insight on the drivers will be appreciated.
dirkdiggler
Suspended
DANX123
drivers.
thanks very much. next question ? how do i know how many teeth to order?dirkdiggler said:
dirkdiggler
Suspended
You need 9 tooth drivers. Your attack has 9 tooth drivers on it already.
MarkAttack
02-579…..No Slip 2.52” Pitch Drive Sprocket, 9T, 1 1/16”-1 1/8” Hexworking away in the summer. doing some changes.
$94.95 Looks to me like a 2006 has a 30 mm hex shaft which is closer to 1 1/16" the Newer models use 1 1/8"
02-574......No Slip 2.52” Pitch Drive Sprocket, 9T, 1 1/8”-30mm Hex (2009 Yamaha Apex, Vecture, Venture 121" & 136") $94.95
The reason I posted two part #'s is because the 2006 Attack has a smaller diameter hex shaft than newer ones do
http://www.wahlracing.com/2.52-No-Slip-Drive-Sprockets.html
I plan to go to fully Clipped does anyone know what is the best tool to cut the windows out of the track ?
4strokes
- Mar 13, 2018
- charlemont ma
- 18 winder xtx 09 nytro xtx 06 apex gt
I would cut them with a credit card, by buying a new track and selling the old. on the other hand, I lost interest in extroverts after one spun on my nytro and blew the backcountry out behind me on the lake. now I run a tight track with no issues
MarkAttack
The Attack has a lot more Horsepower and have to run the Track way too tight and it still ratchets .. Keeps pushing the Hyfax out the back tears the slide rail nylon caps off.. Keep losing track clips . Just made me wonder if I have a bad bearing..I would cut them with a credit card, by buying a new track and selling the old. on the other hand, I lost interest in extroverts after one spun on my nytro and blew the backcountry out behind me on the lake. now I run a tight track with no issues
My 2014 Skidoo 800 137" Track runs a fully clipped track with external drivers only .. and I have no issues with that and can run the track at a tension that does not put it all in a bind..
