Issue on Sidewinder... need some help or ideas.
Status
Not open for further replies.
Had this same issue with mine. Juat spent about 6 hours pressure testing, tightening hose clamps and doing a leak down. Finally got it to hold pressure and thing I have it figured out. Main clamps that were loose were; front heat exchanger, coolant bleeder block, and bottom of t-stat housing. Got the whole damn sled apart for it so I tightened every clamp in sight. Finally held the 16psi for a few hours.
Mine will lose a bit of coolant from time to time, but it’s only when it’s really cold like it was 2 weeks ago. It might lose an ounce or so, and drips out right below the overflow. Fast forward to last weekend, I rode about 250 miles in 3 days and hasn’t leaked a bit.
I have seen this on a few of mine also. I think we have found the problem. I will know in a few days if we can get some riding in.
what do you think it is?
PEFI tune? Is this coincidence or trend?
I wondered if it was over-boosting.. he did see 18 psi on the Stage 3 and 16 -17 on stage 2, and I thought that was odd.. but his exhaust is almost a straight thru design. I am going to check with Thunder and maybe see if there is an update on that tune package.
I dont want to be "Jonny Skeptical" BUT......
It seems when there are burn down/gasket problems on tunes, this tune comes up often.
My guess is the tune for sure caused the failure but there are a lot of factors that can go along with that failure.
Status
