sabrecat
Vendor
- Nov 7, 2013
J&T Products has a brand new product. Super duty 5.63 idler wheels for Cats, Sidewinder and Vipers.. Fits Cats from later 90's to current. Uses the two times bigger replaceable bearings. The wheels have a wider contact area that runs on the track that's strong enough to run on stud heads. Price is the same as stock, $40.00 each.
Website - www.jtatv.com (not on site yet)
Phone # - 810-545-0066
Todd
Todd
Teamblue4
- Feb 20, 2008
- Il.
- 2012 Apex XTX
2013 Apex SE
2014 Apex SE
2014 Apex XTX
Wish you would make these for the Apex's.
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
- 2017 sidewinder ltx dx
2018 snoscoot
Todd
Maybe you have it on your site, but if not you may want to make a note that they will not work for the 2 inboard wheels on each side of shock linkage on the shaft on the 14-18 LTX skids.
twyztid
- Feb 14, 2011
- Middleville, MI
- 2017 Sidewinder LTX SE - TD Power Trail, CAI, 3" Super Quiet
2012 RS Vector
2006 Apex GT
- Middleville, MI
It seems like the inboard wheels are the ones that would take the most abuse from studs. Is this because they are too thick or something?
sabrecat
Vendor
- Nov 7, 2013
Your the second person that asked. maybe it could be something to look into.Wish you would make these for the Apex's.
sabrecat
Vendor
- Nov 7, 2013
Yes I was thinking about that. We had them made offset and as skinny as can be done to clear that linkage.It seems like the inboard wheels are the ones that would take the most abuse from studs. Is this because they are too thick or something?
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
2018 snoscoot
They will clear the linkage but if I saw correctly you are using a 6304 bearing which is 3mm wider than the stock wheel bearing. All the components are stacked on that shaft between rails, so not able to absorb an extra 6mm of width.
sabrecat
Vendor
- Nov 7, 2013
Got a wheel for that location in the works. Will be same wheel with a quality bearing 6004 bearing for the procross sleds.They will clear the linkage but if I saw correctly you are using a 6304 bearing which is 3mm wider than the stock wheel bearing. All the components are stacked on that shaft between rails, so not able to absorb an extra 6mm of width.
WinderFab
- Mar 1, 2009
- Woodbridge, ON
- 2020 Sidewinder Ltx GT
Will Aberfoyle Powersports be stocking these idler wheels ?
sabrecat
Vendor
- Nov 7, 2013
Yes. Not at this time but will be soon.Will Aberfoyle Powersports be stocking these idler wheels ?
Thx
WinderFab
- Mar 1, 2009
- Woodbridge, ON
Awesome..
My inside wheels on my ‘20 are already showing major wear plus they spin warped lol..
Let us Canadians know when Aberfoyle has stock..
TPAY243
- Apr 14, 2013
- Northern Wis
- 2020 Yamaha Sidewinder LTX SE
Todd
TPAY243
- Apr 14, 2013
- Northern Wis
Does anyone know if the Stealth Big Wheel kit I bought for my 2014 Viper LTX 137 fit on the 2020 SideWinder LTX 137. I know this is off topic but if it will fit I will remove it before I sell it. I herd the rear axle was in a different location on the 2020 and up skids I don't know if that's true or if it matters.
sabrecat
Vendor
- Nov 7, 2013
Will not fit. Not one part is the same as the 12-18's.Does anyone know if the Stealth Big Wheel kit I bought for my 2014 Viper LTX 137 fit on the 2020 SideWinder LTX 137. I know this is off topic but if it will fit I will remove it before I sell it. I herd the rear axle was in a different location on the 2020 and up skids I don't know if that's true or if it matters.
Todd
no1b4me
Thanks Todd.... Received our 2 sets of HD idlers, they look very stout and will work perfectly. Looking forward to installing them since we have alot of time on our hands due to new CV19 restrictions
Thanks again!!!
Thanks again!!!
