Xtxcasselman
- Jan 7, 2020
- Casselman
- 2020 xtx le
Xtxcasselman
- Jan 7, 2020
- Casselman
- 2020 xtx le
not sure if this video works,
the bearing inside the chaincase on the secondary shaft appears to be spinning on the shaft itself.
any thoughts from the experts?
Turboflash
- Mar 18, 2019
- Southern MN
Somethings toast. My old eyes can't tell if the bearing is turning on shaft, or if bearing OD is turning in case.
2004yamahaviper
- Sep 11, 2010
- Ottawa, Ontario
- Spring order 2021 srx
2012 Apex xtx
Just had a 2017 viper with the same issues bearing loose and spinning slightly on the shaft.
