Dogrunner
I'm looking to set up my carbs on my 2003 RX-1 to the elevations I run (3000-5000) Has anyone bought the no name carb kit off ebay or do you get it elsewhere? I had read last year the screw setting was 2 1/2 out now I'm seeing 1 3/4-2? Does anyone have a video link to syncing the carbs with a 4 gauge vacuum manometer? Much thanks!
Brotherdan
- Sep 8, 2017
- Belmont,maine
- 2011 apex xtx blue, starr suspension,gytr front shocks,camso 1.5 track cut down, snowtrackers work in process,2003 rx1er originally 121 converted to 136"monoshock 2 ck136 rear suspension with clicker vector ltx shock,muffin works tunnel extension, seat concepts(wrp) seat,apex hooked handlebars converted to all underhood wiring,8"lake effect billet aluminum riser,gytr frontshocks,yamaheater hand warmer kit,rocks ridelite,rocks power supply, rocks heated bag,, tunnel braces,blue skid plate,garmin gps, aggressive snowtrackers on apex single keel skis,rollerski ski wheel kit,108 warthog studs&blue studboy backers,pioneer wheel lowering kit, dupont slides, 4th wheel kit,yamaha saddle, tank& windshield bags, powermadd led handguards, bar mount mirror kit, apex radiator& electric fan added, apex rear cooler,autometer temp guage, apex new style large diameter drive shaft with extroverts machined for chaincase,thunder products clutching,1987 enticer 340ltr 2100miles,1984 enticer 340,1996 wolverine 350,big wheel kit,winch,racks,k&n,full skidplates
All the info I could find was two turns out&that's where I set mine&it runs great.im no help on the kits from ebay although I've seen them.otherwise it's all individual pieces from yamaha.kit looks complete&good quality from what you can tell on pics.also search rx warrior to 136 under redbeard (member name)he has info on carb sync there.brotherdanI'm looking to set up my carbs on my 2003 RX-1 to the elevations I run (3000-5000) Has anyone bought the no name carb kit off ebay or do you get it elsewhere? I had read last year the screw setting was 2 1/2 out now I'm seeing 1 3/4-2? Does anyone have a video link to syncing the carbs with a 4 gauge vacuum manometer? Much thanks!
Dogrunner
I put the carb kit in today Balls to the wall is the brand and it seemed to be good quality. Now to see if I can’t get them synced. Thank you for the info!
Brotherdan
- Sep 8, 2017
- Belmont,maine
Cool good to know kit seemed decent?when you find redbeard posts the info is on page 4&5I put the carb kit in today Balls to the wall is the brand and it seemed to be good quality. Now to see if I can’t get them synced. Thank you for the info!
