SRTGTOCJ7
- Feb 25, 2020
- Jersey/ ADK
- 2023Sidwinder L-TX LE EPS.
2019 Sidewinder L-TX DX
2000 SXR 700
1997 VMax XCT 600
When I bought my 2019 LTx I had the dealer install a 2 up seat. It is removable but its a PITA, need to remove 4 sets of nuts and bolts. Not a problem in the garage but different story on the trail. I have pigtails installed so I don't need to remove the seat to connect the battery tender. I was wondering if their are any quick connect options to connect a battery booster or jumper cables in case the battery dies.
Simplespeed
- Jan 8, 2022
- 1191 Sauk Lane , Saginaw, Mi. 48638
- 2006 Apex , 2017 Sidewinder LTX -LE
You can get a pair of leads used on Apex and connect directly to battery terminal’s and then jump with any portable battery jump box . I carry a Audew and is compact and plenty of power to get the job done ….
WinderFab
- Mar 1, 2009
- Woodbridge, ON
- 2020 Sidewinder Ltx GT
Depends on which booster pack you have or plan on buying. I have a few different Noco booster packs, I have this connected to battery and sticks out under the seat screw, noco booster plugs right into the end. https://no.co/gbc007
Simplespeed
- Jan 8, 2022
Your right …. Same as mine…Depends on which booster pack you have or plan on buying. I have a few different Noco booster packs, I have this connected to battery and sticks out under the seat screw, noco booster plugs right into the end. https://no.co/gbc007
earthling
Make sure you pull the adapter/fuse before you try to jump.
Derek Fosbury
- Jan 18, 2021
- 2022 Sidewinder S-TX GT
2023 AC T-Cat EPS w/ATAC
- Sledding Location - Fenelon Falls, ON
I've got the same setup, which has been great. I have a charger on the wall, use the noco adapter for trickle charging when sled is not being used.Depends on which booster pack you have or plan on buying. I have a few different Noco booster packs, I have this connected to battery and sticks out under the seat screw, noco booster plugs right into the end. https://no.co/gbc007
SRTGTOCJ7
- Feb 25, 2020
- Jersey/ ADK
2000 SXR 700
1997 VMax XCT 600
Yes that’s what I was looking for thanks!Depends on which booster pack you have or plan on buying. I have a few different Noco booster packs, I have this connected to battery and sticks out under the seat screw, noco booster plugs right into the end. https://no.co/gbc007
