just finishing 06 bd25 turbo apex need info
minnesota
well tommorrow i should be able to fire it up and was woundering how a person bleeds the coolant system do you raise the rear way in the air and loosen the bleeder screw till all the air is out ? anythingelse that need to do before or while i fire it up for the first time ? oil system need anything done to it ?
ohyea i tore the motor down to put a headshim and 2 base gaskets in so everything is empty ,
anyone have anytype of setup or close a person at sealevel on the bd box and for clutching
thanks
mike.j
With thermostat removed, put coolant in thermostat housing, bleed air from rear crossover pipe or heat exchanger which you should have with a turbo. Put in thermostat, fill to top. As for oil, you can apply a bit of air pressure to the tank with the turbo oil feed line off and ready to catch oil in a can to get it primed. Once you get oil there, take pressure off tank and install oil line to top of turbo and fire it up. Do you plan on running that on the trail? If so, what are you doing for a silencer? I thought the boondocker dumped right into the tunnel with a straight pipe. Could get a little annoying without a quiet exhaust. Mike Knapp#17
