Just finished servicing 2017 Winder with about 5500kms, decided to open up chaincase and inspect parts.
Outer bolt was loose almost 2 turns, inside bolt was almost all the way out, the only thing stopping it from falling out was rubbing against chaincase.
Top bushing had enough wear that it was getting sloppy, so I changed it.
SumpBuster
- Jul 18, 2003
- Carlisle, NY .
- 18 sidewinder; 06 Apex RTX
Any evidence of loctite? That sounds exactly like mine, no sign of loctite. A friend's sleds were both tight and both loctited.Just finished servicing 2017 Winder with about 5500kms, decided to open up chaincase and inspect parts.
No, not on this one.Any evidence of loctite? That sounds exactly like mine, no sign of loctite. A friend's sleds were both tight and both loctited.
Bringing this back to the front for the guys with new Winders. Just opened a chain case with 1700 miles on it and the machine screw on the back side of the tensioner was backed out about 3/8 of an inch. I don't know how it wasn't rubbing on the back of the case.
Open the case up and get these welded guys and gals
It needed to loosen one more turn......Bringing this back to the front for the guys with new Winders. Just opened a chain case with 1700 miles on it and the machine screw on the back side of the tensioner was backed out about 3/8 of an inch. I don't know how it wasn't rubbing on the back of the case.
klr650r
- Jan 26, 2018
- New Brunswick
- 2018 Yamaha Sidewinder R-TX LE 50th
Opened mine up this weekend...It was time...once again...*Face Palm*
Both sides loose...one side stopped by the chain (Luckily the chain on my '18 sled had streched so much the idler was lined up with the "stupid" reverse chain) ...the other by the case... wonder how long that would have held up.
I have a brand new one I'm gonna weld and I'm gonna weld this one too. Worked great on my 2017.
Jefro
- Aug 22, 2021
- Interlochen Michigan
- 2020 Thundercat iACT
2003 ZR 975
1996 ZRT 992 PS
Add another one to the list...2020 T-Cat Snowmageddon demo sled with 863 miles. Backside bolt 2 very easy turns from falling out.
I have seen a pile of these.Add another on to the list...2020 T-Cat Snowmageddon demo sled with 863 miles. Backside bolt 2 very easy turns from falling out. View attachment 168713
Jefro
- Aug 22, 2021
2003 ZR 975
1996 ZRT 992 PS
The front bolt had red loctite and was tough the whole way out while I can't find a bit of red on the loose rear bolt.
Poor quality control.The front bolt had red loctite and was tough the whole way out while I can't find a bit of red on the loose rear bolt.
GR8BBQ
- Mar 23, 2018
- Hamlin, NY
- 2017 Yamaha SRViper X-TX SE
2017 Ski-Doo Blizzard 900 ACE
2001 Yamaha SXR 700 Triple
1995 Polaris Indy Lite
Picking mine up tomorrow from my nephew who is welding mine as we speak. It was not loose, but fixing it while the chain case is open.
REDLINE 1
I’ve had good luck just cleaning the bolts and holes really good with solvent then reassemble with red locktite. Did this when it was new been checking every year and it’s still holding fine
Pstn head
WELD IT UP !!!
