Key sticking in ignition???
is the key switch plastic or metal on the inside? would heating the key with a flame risk melting something?
Blue Dave said:
Grimm said:
steiner said:
Remove the cover were the ignition switch is mounted to. Bring it inside for a day. Used compressed air and blow out any remaining moisture. Give it a quick spray of WD-40 or Fluid Film. Reinstall panel and it will be better than new.
I've always heard from Locksmiths that graphite spray is best for locks. A little messy though.
Graphite will not displace the moisture like WD-40 or Fluid Film.
Exactly!! ;)!
Went the Fluidfilm route. Went looking for the hot babe, but fluidfilm was far cheaper.
Worked so well, I sprayed it in my Jeep door that was always freezing up- feels like a new lock mechanism now.
