MajorGasAttak
Can anyone tell me what size larger I can get away with on the factory Grizzly rims. It seems as you go up from 25" they also get slightly wider. Im not looking for a radical change, only a slight increase in height and footprint when the time comes for new rubber.
I am pretty sure you can run 26 to 28 if you keep the tire width the same as the rim or slightly wider.
MajorGasAttak
Thanks, that was the feeling I was getting from my own research. Hopefully there will be some time passing before I need new shoes.
Rider11x
Any stock pipe clearance issues?
None that I know of.
