jaydaniels
- Dec 10, 2008
- Bedford NS Canada
- 2017 Sidewinder RTX
I have a 2017 Rtx with a Hurricane SM 270 tune. Qay70 Dalton weights loaded, stock helix and secondary spring. The sled is real lazy bottom end. A stock winder has more snap. I realize there is some turbo lag but to me just doesn’t feel right. I’m seeing 14-17psi for boost. Anything I can do or should look at? Maybe reduce clutch weight?
Norse
- Jan 1, 2019
- Sápmi
- Norway
- 2013 Arctic Cat M1100 HCR 162"
Boondocker turbo 250HP(sold)
2016 Yamaha SR Viper MTX LE 162"
MCXpress 270HP, lots of mods (sold)
2021 Arctic Cat M8000 Hardcore Alpha 155"
N/A (sold)
2023 Yamaha SW MTX LE 153"
M&M Racing 270HP, Elevate, lots of mods
Lighter weights on heels and clean clutches should do the trick!
jaydaniels
- Dec 10, 2008
- Bedford NS Canada
Thanks. Maybe Daltons carry a lot of heal weight? Any recommendations on a better weight?Lighter weights on heels and clean clutches should do the trick!
Norse
- Jan 1, 2019
- Sápmi
- Norway
N/A (sold)
Don't know much about clutching, really. I just removed the heel weights on my BDX weights and it was a perfect fit to my slightly bigger turbo. But because of a reflash that was supposed to help my Viper start easier, it can now drive on its own right after startup (rarely). So I think I'll put very light weights on the heels. I assume your weights are "adjustable" - someone can probably chime in on this, but testing for yourself is pretty easy.Thanks. Maybe Daltons carry a lot of heal weight? Any recommendations on a better weight?
rev them up
- Apr 3, 2006
- Prince Edward Island, Canada
- 2011 Nytro XTX, Hurricane Exhaust, K&N, Pcv, Autotune, Pod300, Star Suspension,
2018 Sidewinder, TD Max Spool 17, CAI, TD 3 Inch Stock Muffler Mod, 3Bar, BOV
Need a little more info for anybody to help. What belt are you running? What are your rpms?
Crossfire12
- Feb 13, 2017
- New York Adirondacks
- Sacandaga reservoir
When you punch it ,it should go to the rpm’s max for that tune, need more info, could be heavy weights, helix. Start empty,
tsiceman
- Jan 31, 2006
- Fishers, In
- Winder ltx le
Last yr I ran qay70s 74.5g set screws bottom out to tip.
Powertrail, trail muffler, stock airbox, stock springs and stock 35 helix. Xs825 belt
jaydaniels
- Dec 10, 2008
- Bedford NS Canada
Running the stock belt. I’ll check rpm tomorrow. Works fine when my speed and rpm’s are up. It’s when I’m cruising along at 20-30mph. Just has no snap at all. It seems very slow to build power.Need a little more info for anybody to help. What belt are you running? What are your rpms?
Big_Phil
- Feb 5, 2014
- Wasaga Beach, Ontario
- Sidewinder RTX LE
EPI purple secondary spring at 0-1 or equivalent, or you have a boost leak possibly. Sled should be an animal from a 20-30 roll. That’s the best speed for my RTX to hit from.
- 7K
- 6K
