Eric4440
- Jan 15, 2018
- Hudsonville, MI
- 2014 Viper XTX
both the left and right side heat exchangers on my Attak are leaking by the suspension mount. The part numbers between apex, and vectors and attaks are different, will the exchangers still work on mine and line up? Have an opportunity to buy some good used ones off a newer vector
Snowman11
Why are they leaking ?
RAMSOMAIR
Sand and stones get in between the exchanger and the tunnel and wear,
Snowman11
Oh wow , never even considered that ! Musta been alot of sand, lots of vibration over many miles
- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
Vector heat exchangers are smaller in capacity, they won't cool the engine enough.
Eric4440
- Jan 15, 2018
- Hudsonville, MI
- 2014 Viper XTX
Okay thanks for the reply. Now as far as rivers go, I have read a lot about buying them from avdel, the stavex or whatever to save some money, but I am wondering if you can get them in black or the yellow zinc plated? Cause I believe the ones from Yamaha are coated... if the ones from avdel aren’t I’d rather bite the bullet than possible have corrosion issue down the road.
yamadoo
- Jun 3, 2003
10 Vector LTX Blue 9kmiles
11 Venture GT 4k miles
86 SnoScoot(2) for grand kids
is this something you could just clean, rough the surface up and seal with JB weld. I say this as I put a stud through a front heat exchanger in 98 did this and proceeded to put on 14k miles and looked as good as the day I put it on and NO LEAKS ever. Saved big $ and time.
Standard issue with Attaks. The extra length allows more flex in the boards which cracks the exchangers.both the left and right side heat exchangers on my Attak are leaking by the suspension mount. The part numbers between apex, and vectors and attaks are different, will the exchangers still work on mine and line up? Have an opportunity to buy some good used ones off a newer vector
Install some tunnel reinforcements plates and you should not crack the exchangers again.
