Mik mort
- Feb 7, 2018
- Fargo
- Yamaha apex
- Fargo
Put a set of Zdatt H-4 bulbs in a 2011 Apex. The inside of the lens now frosts over. Anyone else having problems with this? Solutions?
Not all cracked up to be, are they. I have tried Led bulbs in the past. Went back to the ultra reliable OEM halogen. Led does not provide any heat. Frost inside and out
Take the headlight pod in and dry it out. Then check for any breaks in the seal of the housing
Mik mort
- Feb 7, 2018
- Fargo
- Yamaha apex
- Fargo
It's not the bulbs themselves, but the lens of the whole headlight assembly.Take the headlight pod in and dry it out. Then check for any breaks in the seal of the housing
Mik mort
- Feb 7, 2018
- Fargo
- Yamaha apex
- Fargo
Not in mine anyhow. They work great in a viper though.Not all cracked up to be, are they. I have tried Led bulbs in the past. Went back to the ultra reliable OEM halogen. Led does not provide any heat. Frost inside and out
blueironranger
- Feb 3, 2009
- Iron Range MN
- 2014 Viper XTX
2009 Phazer MTX
This is why I added mini LED light bars to my sleds, LED bulbs just don't throw enough heat to keep the lens cleared, especially if your following someone and snow dust starts building up on the lens. Another reason is I have extra light when I need it, and it can be turned off so I don't dazzle oncoming rider at night or highway traffic when riding ditches. Way to many riders out there tossing in the cheapest/brightest LED bulbs they can find without concern to fellow riders, there are VERY few LED bulbs on the market that work well standard halogen housings.
Yup. That's why you want to dry out the headlight pod/assembly and check the seal.It's not the bulbs themselves, but the lens of the whole headlight assembly.
Do you park the sled on a heated garage? If so this will also produce moisture in the pod and the LEDs do not produce enough heat to melt or dry the pod out.
Mik mort
- Feb 7, 2018
- Fargo
- Yamaha apex
- Fargo
Thanks I'll try that.
InRBigness
- Apr 10, 2014
- winnipeg, manitoba
for brighter light, without frosting of your lens: Get a set of Roctoyz HID kits. Hundreds of us TY sheep cant be wrong.
03RX1-ER-LE
Bleed BLUE
- Feb 22, 2008
- 2011 Apex XTX 12,497 miles
2009 Apex ER 8,169 miles
Tow Vehicle
2021 Wolverine X4
- Livonia Michigan
Love my HIDs from Rockfor brighter light, without frosting of your lens: Get a set of Roctoyz HID kits. Hundreds of us TY sheep cant be wrong.
slowride06er
Going to look into to this. Funny I did talk to him todayLove my HIDs from Rock
Mik mort
- Feb 7, 2018
- Fargo
- Yamaha apex
- Fargo
Do the HID lights make heat so as not to frost over? Also do you use the stock rubber boots with HID to keep moisture out?for brighter light, without frosting of your lens: Get a set of Roctoyz HID kits. Hundreds of us TY sheep cant be wrong.
Yes and yesDo the HID lights make heat so as not to frost over? Also do you use the stock rubber boots with HID to keep moisture out?
Mik mort
- Feb 7, 2018
- Fargo
- Yamaha apex
- Fargo
Ok thanks.Yes and yes
DLXB12Ss
- Mar 4, 2016
- Oakfield, Wisconsin
- 2011 Vector GT custom paint
2006 Apex ER custom paint
I want to do that also, just can't find the lights or bars I like. Can you send some pics of what you're running?This is why I added mini LED light bars to my sleds, LED bulbs just don't throw enough heat to keep the lens cleared, especially if your following someone and snow dust starts building up on the lens. Another reason is I have extra light when I need it, and it can be turned off so I don't dazzle oncoming rider at night or highway traffic when riding ditches. Way to many riders out there tossing in the cheapest/brightest LED bulbs they can find without concern to fellow riders, there are VERY few LED bulbs on the market that work well standard halogen housings.
