srxtim26076
- Dec 12, 2007
I sunk my sled in the bottom of the lake a few weeks ago. I drained oils ect. and sled runs ok. THe only problem is that the headlights and tail lights go off intermittently. Usually when I first start the sled, I have to run it for a mile or so before they go on. ALso I put HID lights in. is there a relay for these lights? thats maybe wet? shorted?
Zakre
relays must have water in them
srxtim26076
- Dec 12, 2007
do you have idea of where the relays are? which one is for lights?
raginyamaha
- Jan 11, 2007
- Waterford, wi
- 2013 xtx
they arent sealed- you should replace all of them just as a precaution. pull out the manual some by the battery and some on the other side i think.
dansranger
In the "sticky" FAQ topic there is an illustration.
