cowman2
Ok, looking for some suggestions for a back up sled. I want to be able to limit the throttle on a RX-1 for less experienced "guest" riders..and then be able to ride full throttle when I take it out to play. Can any of you guru's make some suggestions for ease of use?
thanks
thanks
jmbones
Tape a block of wood behind the thumb throttle to limit it. Remove the tape when you're ready to ride.
4Fighter
- Oct 28, 2003
- Sault, MI
- '07 Attak GT
Try a hose clamp.
cowman2
thanks, I was thinking something along those lines. maybe a cable clamp on the carb end of the throttle cable? limit how far they can pull.
LazyBastard
Be careful with anything that will bend or kink the cable as it may not slide smoothly in the jacket after that. Another option you *might* be able to get away with is just loosening the cable way off. Then they'll be able to put the lever all the way to the bar, but it won't open the throttle fully.
race24x
- Dec 29, 2003
- Belgrade, Maine
- www.r-scomputer.com
LB exactly what I was going to say if you adjust your throttle cable so there is slack in the thumb peice it wont open the butterflys fully but about 90% maybe been a thing to look for when you seem to be lacking some power for years
HEAVYD
Dont over do it, or the cable housing may pull
out at the handlebar and actuate your TORS
