ontarioyamaha
- Mar 26, 2017
- Port Perry, Ontario
- 2010 Vector ltx GT
2010 MXZ X 1200
- Port Perry
Finished up front end, set up exactly as per Catman. Every adjustment was out to lunch, max setting on clickers, no preload on springs.
Now I am pulling apart the rear skid and I am finding much the same, missing rear cable and the shock is set to max clicker and max preload. The transfer rod was out well beyond max. I also noticed that the limiter strap has been in every conceivable position.
I want to place in stock positions to continue on Catmans setup. Does anyone know where its is when stock?
thor452
Because I can
- Jan 5, 2010
- Shawano,WI 54166
most always is 1 hole in from full out
