Northern Viking
Hello.
I noticed one of my limiter straps snapped completely. The other one looks fine so I hope the front shock didn't take too much damage.
Are theese hard to replace? I've never done one so I'm a bit of a noob on it, but think it's time to learn... I've sourced a universal one that will fit according to the shop. It's 24" long and 1,6" wide.
Thankful for any advice.
Mooseman
- Nov 3, 2009
- Greely, Ontario
- '07 Venture MP (gone)
'07 Phazer FX (gone)
'09 Phazer GT (gone)
'10 Nytro FX (son's)
- Greely, ON Canada
Shouldn't be that hard especially since you still have a good one holding. Mine broke both and destroyed the shock. I wound up leaving an old one on as well as the two new ones. Extra insurance.
YukonMP
- Dec 25, 2014
- Yukon Territory
I would place a small piece of lumber or a small log(about three inches) in front of the track and just pull up on to it. That should give you enough slack to work with. Don't over do it or else it will be hard to match the tension in the two straps. You won't be able to match them perfectly so make the new one tight so it can stretch to match.
You are in Sweden so you can handle this but most of TY would be jealous to know it is -7C here, snowing, and we have a snow pack of 28 inches.
Northern Viking
Not sure I understand the log trick. I have the sled lifted on the rear in my garage, the track is completely if the ground, so I thought I would install a new limiter strap and just tighten it until I see it starting to lift on the other one? The other one is still there in nice condition, holding it up. Is this method bad or not appropriate?
Yeah I'm in northern Sweden. We have about the same conditions, although the trails are very hard now and barely any snow on the lakes.
YukonMP
- Dec 25, 2014
- Yukon Territory
You've got a good plan.
