corvette joe
- Feb 7, 2011
Hey gang, can anyone give me the best location to mount my Duraflex scratchers on the skid of my 2020 viper? Cheers….
Never had much luck with those.. ends fall of for me.
Wannaviper
- Mar 18, 2014
- West Gardiner, Maine
I have used the Duraflex scratchers with good luck for @5,000 miles. Conventional wisdom says to put them as far forward as you can to distribute the ice/snow over as much of the length of the track as possible, but I found a hole in my 137" skid a little more than 1/2 way back that lined up so that I could hook the scratchers over the rail when not in use. If I remember correctly, I had to drill out an existing hole to a larger diameter, and it has worked very well so far.
yamadoo
- Jun 3, 2003
10 Vector LTX Blue 9kmiles
11 Venture GT 4k miles
86 SnoScoot(2) for grand kids
I was amazed how despite mounting farther back than I liked, I have the DOO dual spring scratchers on a TeamFast King Air rear suspension that the WHOLE rail of the track is still well lubricated and the cooling was much enhanced. So I believe anywhere that gets snow/ice dust ie WATER in the turbulent air flow of the track does the Lube and Cooling job it is intended for. My 2 cents
corvette joe
- Feb 7, 2011
Thanks again gang, great forum.
Northernshift
- Nov 27, 2014
- 2013 Vector LTX
Hey Corvette, which skis and runners do you have on your Viper?Thanks again gang, great forum.
corvette joe
- Feb 7, 2011
Hey Northernshift, I have the stock tuner skis with Snowtrackers. They work awesome. Handles like it’s on rails.
Northernshift
- Nov 27, 2014
- 2013 Vector LTX
I have the same set up. My only complaint is that I had to back off the ski shock springs way down in order for the trackers to work properly. Because of that, my A arms are sagging a little, I don't like how it looks. It handles excellent otherwise.Hey Northernshift, I have the stock tuner skis with Snowtrackers. They work awesome. Handles like it’s on rails.
corvette joe
- Feb 7, 2011
I left the stock set up and works great. I’m only 170lbs so might make a difference. All good. Let it snow baby. I’m ready
APEXJOCKEY
- Jan 6, 2006
- New York
- ‘20 XRS 900 Turbo
‘22 Thundercat EPS
Here is where I’m going to drill a hole and mount the Ice scratchers on my new ‘22 Thundercat, then I’ll hook the carbide tip on the rail in the lowest notch in front of the rubber block. I have this same setup on my ‘20 XRS Doo 900T and the skid is always full of snow with normal engine temps. No issues.Hey gang, can anyone give me the best location to mount my Duraflex scratchers on the skid of my 2020 viper? Cheers….
Wannaviper
- Mar 18, 2014
I weigh 100 pounds more than you, and left the shocks the way they came from the dealer, and I am very happy with the Tuners/Snow Trackers.I left the stock set up and works great. I’m only 170lbs so might make a difference. All good. Let it snow baby. I’m ready
srvfan
- Nov 9, 2004
I have the scratchers mounted to my skis with the BOP kit Which is a bit scary if they snag something even though they are built to break away. Has anybody found a place to mount them on a 129” rail ? Seems like there really isn’t room
1999 Fatboy
- Nov 15, 2019
- 2018 Yamaha SR Viper LTX-DX
I use the OTTP reversible ice scratchers that mount to the skis when riding in icy or hard pack conditions, they work quite well. I used extra washers on the skis because I had them down when backing the sled off the trailer one time and one of the scratchers caught causing the plastic on one ski to bend a little.
spwild47
- May 14, 2011
Hey Joe…have stock tuner dual keel and thinking about getting snowtrackers. Are they part #194173? And did you have to buy 2 sets to get 4 U channels and 4 carbides?Hey Northernshift, I have the stock tuner skis with Snowtrackers. They work awesome. Handles like it’s on rails.
corvette joe
- Feb 7, 2011
