Loctite is your friend!
grizztracks
TY Advertiser
Scio, NY
FX Nytro RTX, RS Vector, SR Viper RTX SE
Don't skimp on the loctite when replacing parts on your sled. Yamaha's lock nuts are junk and even if there's a cotter pin to prevent the bolt from falling out use loctite to keep things tight. I replaced the subframe on my Nytro a couple of years ago and obviously forgot to loctite the bolt that goes through the steering pivot arm. My steering got extremly loose while on a ride and I limped it home to find out the nut backed off against the cotter pin and because I ran it loose it egged out the hole in the subframe. A little weld, grinding and plenty of loctite and it's ready to go again. Unfortunately I had to remove the subframe to do the repair. last year I had the upper a-arm bolts loosen and almost fall out while riding.
I had the same problem with mine. When I pulled the bolt out it was covered in grease.
lots of red loctite on everything......... ive had something every year come apart/loosen up on me.
