quinners318
Just as the subject states, has anyone had issues with the life of a cut down 15" track? I'm strongly considering ordering a 15" track and cutting it down since there are a few good deals out there for them.
blueironranger
- Feb 3, 2009
- Iron Range MN
- 2014 Viper XTX
2009 Phazer MTX
as long as you take your time then no, no issues. I've never cut a phazer track but I have done a few for AC sleds with the 13.5" track. I've always run a propane torch around the cuts to quickly melt up the cords so they look prettier, don't think it helps with durability though.
LEE337
Do it! Should be no issues. 2000 miles on mine and looks the same as it did when i started.
Leno
- Jan 18, 2010
- Lindenhurst Il
- 2008 phazer 151
There is no issues with mine and I put my sled through so much each year
Ruckus
Worked great for me.
quinners318
Thanks guys! Looks like I'll be buying a 15 incher and saving some cash! Happy sleddin!!!
UP bushman
I cut a 144 X 1.75 Back Country down to 14.25 wide with no problems. Recommend you use NEW saw blade with a soapy water solutuion for lube and you have what ever track you want.
