VX1R
- Sep 19, 2004
- Inver Grove Heights, MN
Current Riders:
2018 SW LTX-LE
2002 SRX Custom
Vintage Riders:
1980 Enticer 300 Twin
1986 Inviter
1998 Phazer Mt. Lite
1996 Phazer Mt. Lite Mod
Since it's summer time and some of us like to keep busy working on and talking about sleds 24/7, I thought that I'd ask for opinions from guys who've actually had a chance to test drive both a '07 RTX and a '07 Attak GT.
I'm looking at converting a '06 Apex GT using a 136" x 1.5" lug track along with using a ProActive skid with extensions and Ohlins shocks in the skid. Not sure about keeping the GYT clicker front shocks or switching them out for a set of Ohlins or Floats.
I like the advantages of the 136" track length over the stock RTX and would like to end up with a more aggressive bump riding package than a '07 Attak GT.
Anyone who's had some time on these sleds care to chime in with any thoughts on what I've got in mind?
Turtle
- Feb 27, 2006
- Marathon, WI
'07 FX Phazer GT
I think you've got a good plan going there. I myself have an '06 Nytro, which has the ProActive CK suspension - which is the suspension that will come in the '07 Apex RTX.
I am right now in the process of stretching it to a 136" with a Ripsaw 1/5" lug, and can't wait to see how it performs.
nbsledder
Gade-thrasher......Free nytro from snotrax?Just curious , are you the lucky winner?
Swiss Sledder
Talked with two guys that rode the Attak GT. They said it had the best ride of the lot, hands down. One has a 06 Apex GT and the other has an 06 Attak.
The Attak GT that I rode was hands down better then my Apex GT !
jimmie d
Don, why don't you just switch skids and shocks with your wifes Attak plus use the Attak tunnel ext., even though I prefer the MPI or Hartman tunnel ext.
Should be easy for you and than you have an Attak GT.
Jim
Jim
SledFreak
- Feb 7, 2005
- Ontario. Canada
It will be as slow as hell if you do that, especially with that track. It may go good from 0-50 and then die after that.gade-thrasher said:I think you've got a good plan going there. I myself have an '06 Nytro, which has the ProActive CK suspension - which is the suspension that will come in the '07 Apex RTX.
novarossi
- Dec 26, 2005
Why??SledFreak said:It will be as slow as hell if you do that, especially with that track. It may go good from 0-50 and then die after that.gade-thrasher said:I think you've got a good plan going there. I myself have an '06 Nytro, which has the ProActive CK suspension - which is the suspension that will come in the '07 Apex RTX.
SledFreak
- Feb 7, 2005
- Ontario. Canada
First you are turning your Nitro from a 121 to a 136, way more trackto turn. Second, that big of a lug will kill it's already slow top end. That length and size of track becomes a big windmill and you now have alot of weight to spin. Just change the track, I would not do both on that sled.novarossi said:Why??SledFreak said:It will be as slow as hell if you do that, especially with that track. It may go good from 0-50 and then die after that.gade-thrasher said:I think you've got a good plan going there. I myself have an '06 Nytro, which has the ProActive CK suspension - which is the suspension that will come in the '07 Apex RTX.
obr
I was lucky enough to get some miles on an 07 RTX. It was the most fun sled I've ridden to date. Have also ridden 06 RTX, Apex GT and Nytro, but none of them could compare to the RTX 07. I think with a little more traction it would be something to considier. I think you are on the right path here.
Turtle
- Feb 27, 2006
- Marathon, WI
'07 FX Phazer GT
nbsledder said:Gade-thrasher......Free nytro from snotrax?Just curious , are you the lucky winner?
Yes I am!!
Turtle
- Feb 27, 2006
- Marathon, WI
'07 FX Phazer GT
SledFreak said:First you are turning your Nitro from a 121 to a 136, way more trackto turn. Second, that big of a lug will kill it's already slow top end. That length and size of track becomes a big windmill and you now have alot of weight to spin. Just change the track, I would not do both on that sled.novarossi said:Why??SledFreak said:It will be as slow as hell if you do that, especially with that track. It may go good from 0-50 and then die after that.gade-thrasher said:I think you've got a good plan going there. I myself have an '06 Nytro, which has the ProActive CK suspension - which is the suspension that will come in the '07 Apex RTX.
In my experiency, long-tracks always work better in the big bumps and moguls. I also love doing a bit of off-trail riding. I really have no interest in top speed.
My riding style is to hammer through mogul section, ride some deep stuff, and stay off the rail-grades and lakes. Therefore, long-tracks fit my ride style. My last sled was also a long track. I'll never go back to a short track!
Soldier'spapa
- Mar 21, 2006
- Naperville, IL
- 2018 Sidewinder Ltx LE 50th Anniversary
MrSled said:The Attak GT that I rode was hands down better then my Apex GT !
I have read many posts/threads concerning the need for aggressive riders (Also Heavier guys) to revalve the Ohlins shock firmer and replacing the stock spring with a heavier one. My question is; Does anyone know if the 07 Attack GT is sprung/dampened the same as the 06 Apex GT? If it is would you recommend for a 220# aggressive rider to firm up the rear suspension prior to the snow season or try it the way they ship it first? I have limited riding time and wish not to spent a lot of that time on a ride I am not absolutly thrilled with. The trails I ride are a mix of long straight aways, tight twisties and some off trail.
VX1R
- Sep 19, 2004
Current Riders:
2018 SW LTX-LE
2002 SRX Custom
Vintage Riders:
1986 Inviter
Soldier'spapa said:MrSled said:The Attak GT that I rode was hands down better then my Apex GT !
Doug,
The '07 Attak GT has firmer compression valving along with a higher rate spring than the '06 Apex GT. I recently had Bruce Schrader from Pioneer Performance make the change on a '06 Apex GT Ohlins EC shock to the same specs as the '07 Attak GT. I'm using this shock on a 136" monoshock skid and wanted the shock to have the correct specs for the 136" skid. He checked with Ohlins USA and they gave him the valving and spring specs that I mentioned above. From some of the responses so far on this thread from guys that have been on the '07 Attak GT it sounds like they've been pretty happy with the new set up compared to the '06 Apex GT.
VX7R
SledFreak
- Feb 7, 2005
- Ontario. Canada
I think getting the 07 Spec for the Apex GT would be better because the Apex is a 121, and putting the 07 Attack setup could cause the Apex to be a rougher ride. I don't know all of the specs, but it may work on the Attack , but neccesarily on the Apex. The length of the 136 may absorb the stiffer spring and valve calibration, but it may not work for the shorter 121 skid. There are different angles of how the suspesion works through it's travel cycle just to say it will work.VX7R said:Soldier'spapa said:MrSled said:The Attak GT that I rode was hands down better then my Apex GT !
Doug,
The '07 Attak GT has firmer compression valving along with a higher rate spring than the '06 Apex GT. I recently had Bruce Schrader from Pioneer Performance make the change on a '06 Apex GT Ohlins EC shock to the same specs as the '07 Attak GT. He checked with Ohlins USA and they gave him the valving and spring specs that I mentioned above. From some of the responses so far on this thread from guys that have been on the '07 Attak GT it sounds like they've been pretty happy with the new set up compared to the '06 Apex GT.
VX7R
- 147K
