bleedyamaha
- Sep 28, 2013
- Northern Iowa
Great pics. They will only keep getting more loose as you ride. Just sayn
bleedyamaha
- Sep 28, 2013
- Northern Iowa
From talking to my service tech this has been a common problem with the AC tunnels. He had replaced several. I feel I am in good hands having them take care of it. Just wish this would have been taken care of before production began.So it sounds like this is a legit claim on warranty. Meaning Yamaha is actually backing it up! Hopefully this doesn't happen to to many of us..
Kerrdog569
- Sep 11, 2014
- East jordan,michigan
- 2017 Yamaha sidewinder xtx se
Wow that's not good! Thanks for the heads up I'll be watching for these now
stingray719
Had this happen many times when racing stock cars. Nature of the beast so to speak. No loose rivets on ours so far, if I do get a loose one I am going to try the rivet washer on the back of a new rivet trick with a super hard rivet.
Kerrdog569
- Sep 11, 2014
Lol you must have an air powered rivet gun or Popeye forearmsHad this happen many times when racing stock cars. Nature of the beast so to speak. No loose rivets on ours so far, if I do get a loose one I am going to try the rivet washer on the back of a new rivet trick with a super hard rivet.
Yes all sleds this does happen eventually just not this fast. Good idea on the backing washers. Sure looks like that casting on mine is moving around. I have seen Sno X guys snap them. For sure I will be addressing those.
stingray719
Those hardened rivets an air rivet gun is almost a must. I bought mine at Harbor Freight back when I did an Apex front bulkhead replacement. Tried one with hand riveter and said NO! If I remember right this is the one I bought,
http://www.harborfreight.com/14-in-air-hydraulic-riveter-61482.html
Kerrdog569
- Sep 11, 2014
I've replaced a few by hand with my snap-on rivet gun and that sucked!! Bout broke my wrist lol,I should probably get one of those rivet gunsThose hardened rivets an air rivet gun is almost a must. I bought mine at Harbor Freight back when I did an Apex front bulkhead replacement. Tried one with hand riveter and said NO! If I remember right this is the one I bought,
Air riveter is sure nice. Use mine often also. Does a better job than by hand since by hand you cant always keep riveter straight when compressing it.
stingray719
If you replace a rivet don't use common soft ones, get the hardened ones.
Kerrdog569
- Sep 11, 2014
made that mistake once on my polaris,the rivets holding the rear suspension brackets on fell out so I replaced with regular rivets and let's just say they didn't last very longIf you replace a rivet don't use common soft ones, get the hardened ones.
I emailed Mountaintech. Hoping he will make up a kit. I assume the Yamaha rivets are superior to these cat ones. It looks like the cat ones are hardened if the pull pin being black is a indicator. Just either not tight enough or not enough of them.
cnybrian
- Oct 6, 2011
- Cato, NY
- 2006 Yamaha Attak
- Cato, NY
I am getting ready to replace my tunnel coolers and don't really want to hand rivet everything. Do I need the 1/4" or will a 3/16" rivet gun work?
WVTurboLTX
- Nov 9, 2014
- 2009 Nytro XTX
2017 Sidewinder LTX LE
I have the same harbor freight rivet gun. It comes with different nose pieces for all different size rivets. The 1/4" reference is the air inlet size not the rivet size. Though that gun can do 1/4" rivets.
Mountaintech
Harbor Freight offers basically 2 air riveters, a 3/16" and a 1/4". This refers to the largest size rivet that the tool is rated for pulling, not the inlet air size. The rivet best used for general sled repair is a steel multigrip style rivet. It pulls very nicely, has good clamping force and is designed to "fill" an oversized hole.I have the same harbor freight rivet gun. It comes with different nose pieces for all different size rivets. The 1/4" reference is the air inlet size not the rivet size. Though that gun can do 1/4" rivets.
