Low speed miss and iratic rpms when idling
Age
51
NL
Canada
2012 Yamaha Venture RS TF
Hi, just bought this used sled , 2012 rs venture and it seems to operating a little rough on idle. At slow speeds , seems as though you can feel a miss in the engine.
Just bought new spark plugs to give that a try if I can find them on the sled.
Any ideas ?
valve cover is where the coils are mounted that you need to remove to get to the plugs. on some models you need to remove the headlamp bracket from the frame to get at the coils.
Any ideas ?
Any idea if gummed up jets are a common issue with sleds being unused for a period of time ?
the pilot jets on them do plug easily when they sit. just order new ones as everyone says they are a pain to clean.
