SteelerJim
- Dec 6, 2010
- Rockton, Pa
- 2011 Nytro XTX
Hi, I have an '11 XTX with the OFT relocate and I'm looking to lower the bars back down a couple inches and I am hoping you could set me up with what I would need in order to do that. I was told and saw on the Yamaha fische that the rtx has straight bars unlike the bent xtx bars. I would like to lower it at least a couple inches. Will the rtx bars work? I guess I will need new handwarmers and grips I'm guessing. Any other bar choice is welcome. Thanks.
P.S. the MTX ski's you sold me work fantastic with the Snowtrackers.
Port-Parts
TY Advertiser
- Sep 18, 2003
- Port Washington Wi
- www.portyamaha.com
- 2012 Nytro RTX
2018 Sidewinder BTX SE
I think the RTX bars might work however I bet they are a solid 3-4 inches shorter as they are almost flat with no rise. If you look at your sled and can envision the bars being flat across with the handlebar clamp that is how low they would be with that bar. You definitely would need to get new heater elements and grips as well.
