grooter
- Feb 23, 2007
anyone know that max lug hieght that can be used on an 07 apex rtx 121" ex. 1.5, or 1.75
suprfst
- Dec 4, 2004
- Tawas Michigan
- www.smcfabrication.com
Without being notched you can go 1.5 but if you notch track or it is notched you can go up to 2", Ive done it.
Drives and track have to be perfectly positioned to get them in and out, this is with oem 9 tooths drivers,im sure a 8 tooth would fit fine. And if your going that deep of a track youd be better off wth 8 tooth drivers as it will get you closer to the gearing youll need.
ApexMuscle1000
- Jul 22, 2008
- FARGO, ND
- 2013 YAMAHA NYTRO MTX 153"
Im looking too put an 1.5" on mine did the tunnel protectors need too be removed too fit a 1.5" ?
lawmanbsi
ApexMuscle1000 said:Im looking too put an 1.5" on mine did the tunnel protectors need too be removed too fit a 1.5" ?
1.5 will fit with protectors in
