turbo800
- Jul 24, 2014
- UT
- '15 Viper MTX 162 LE w/ MPI 180 turbo
In case anybody was wondering how the new '15 M7000 or MTX Viper stacked up weight wise against an M8000 2 stroke, here's your answer........the short answer, M8000 is 500lbs fresh out of the crate and the M7000 is 544lbs. No fuel or oil added!
The M8k is a 162 vs a 153 on the M7k so another 5-6lbs would probably make them equal, call it 50lbs heavier...
Photo credit to Madmax
Mountaintech
Nice. Nice scale too. I have the same one and it's pretty accurate, even down low.
turbo800
- Jul 24, 2014
- UT
I think you have it backwards. You would have to subtract 5 lbs from the M8 to make it equal to a 153 track length.Nice. Nice scale too. I have the same one and it's pretty accurate, even down low.
turbo800
- Jul 24, 2014
- UT
You must have edited your post....lol
yamaha1973
- Nov 27, 2011
- St. Peter Minnesota
- 2014 Viper XTX SE
The M8000 have electric start?
turbo800
- Jul 24, 2014
- UT
I doubt it...
yamaha1973
- Nov 27, 2011
- 2014 Viper XTX SE
Thats makes the difference even closer, to be fair you could add another 20-25lbs to the M8000...
turbo800
- Jul 24, 2014
- UT
True. I seen a thread of a guy taking off his E-start on his '14 M8000 and it weighed 12kg or 26.5lbs
tapex_07
- Feb 15, 2009
'07 Apex RTX SC2 MPI 128x1
Is that a 2.25 on the 153? I see a front bumper difference and the tunnel bag on the M8.. just something to point out. I know it's small, but they are close to exactly the same.
Thanks for the post tho!! I was really curious as to what the M8 162 weighed!
Mountaintech
Yeah, I did. Shouldn't post on an empty stomach! Wasn't thinking straight.You must have edited your post....lol
stingray719
Hey, I read a caliper wrong...............
Janzka
We weighed in yesterday for my stock MTX with A full tank of petrol,oil and coolant, tunnelbag, tools, pump and both skid plates. We got 277 kg / 611 lbs. Not bad at all. My friend's M8000 with turbo weighed 276kg /608 lbs.
Nytro40th
- Sep 19, 2007
- Amherstview Ontario
- 2014 SR Viper RTX SE
Swap the lead acid battery to lithium and that is about an 11 lb drop of weight and an aftermarket muffler can be another 5 to 10 lb drop depending on your desired vendor. The sleds are closer than most think in weight, even without these mods.
Janzka
Yes. I will swap lithium battery later. But I will put turbo 190hp or 270hp. Then horsepower/weight ratio is 1 (1hp/1 kg ) Should be fun!Swap the lead acid battery to lithium and that is about an 11 lb drop of weight and an aftermarket muffler can be another 5 to 10 lb drop depending on your desired vendor. The sleds are closer than most think in weight, even without these mods.
Nytro40th
- Sep 19, 2007
It definitely will be lol
