M8000 vs M7000 weights
We weighed in yesterday for my stock MTX with A full tank of petrol,oil and coolant, tunnelbag, tools, pump and both skid plates. We got 277 kg / 611 lbs. Not bad at all. My friend's M8000 with turbo weighed 276kg /608 lbs.
Yes. I will swap lithium battery later. But I will put turbo 190hp or 270hp. Then horsepower/weight ratio is 1 (1hp/1 kg ) :D :D Should be fun!.
Now to be clear is the m7000 with out turbo and the m8000 with turbo. I would imagine the turbo adds a lot of weight to the two stroke with having to install an oiling system for the turbo and a turbo would add a little weight to the 7000 as well
My buddy just picked up a new scale so I figured that I would weigh mine. (153" 2.6" track) Subtract 4.5 pounds for the weight of the tie downs.
Sled has,
Gripper skis -2lbs
BDX rear skid arms -4lbs
Carbon fiber tunnel extension -2lbs
2 idler wheels removed -2lbs
Radiator delete, tunnel cooler added +3lbs
2016 38" front end
Tool kit, spare belt and 5 gallons of fuel in the tank.
