sledheadgeorge
Took my secondary in to get it machined. Needed 4mm cut to get the offset right.
When I picked it up they machined the wrong side of the hub. #%&ck. Will this affect the helix travel?
Byam
Yes toasted
you need this part; 8KC-17660-00-00
KnappAttack
- Feb 19, 2004
- Welch MN
- 2023 Sidewinder LTX-LE
2017 Sidewinder LTX-LE
Hang on. 4 MM even if off the right side will put the movable past the end of the shaft. If you have to machine that much I'd check the PTO shaft on the engine because its moved inward.
Back to machining of the wrong end. If the helix still has half the bushing left it rides on it should be fine, however, you will need to machine the alum plug and use a washer that is smaller than the helix bushing and is not going to bind it up and hold it on the shaft. You will also probably need to shim for the belt deflection differently rather than using washers on the end of the shaft, use washers inside the driven clutch for deflection I mean.
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
At 4mm with no shim the clutch movable sheave will hit the bearing housing for the jackahaft.
Do what Knapp said.
Do what Knapp said.
scooterwj
I had 3mm machined off mine based on feedback on here that anything more is too much.
sledheadgeorge
Thanks guys. Im out grooming today. I'll do that tomorrow and let you know.
Turboflash
- Mar 18, 2019
- Southern MN
A
For me, ANYONE who is "out grooming" is my hero. Thanks!Thanks guys. Im out grooming today. I'll do that tomorrow and let you know.
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
×2A
Pstn head
X3A
RAMSOMAIR
Grooming......need snow for that!
sledheadgeorge
Do what Knapp said.
That takes into account the 2mm washer and cerclip I will put back on. That's why I had it cut. Removed the circlip and washer but still wasn't enough offset.
ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- 2015 Viper 270 hurricane,
- Wisconsin
I say run it!That takes into account the 2mm washer and cerclip I will put back on. That's why I had it cut. Removed the circlip and washer but still wasn't enough offset.
sledheadgeorge
Great news. Machined the spacer and set the deflection. It's all good
