Ethan_Messinger
- Jan 17, 2016
- Wisconsin
- 2011 Yamaha Nytro XTX
2011 nytro xtx. studded 1.25 track. Stock engine
Going through belts every 100 miles this season. 1 of the 7 belts lasted 400 miles.
Ride trails in the U.P. 90% of the time, 10% off trail.
Spend nearly $700 in belts this season
sheaves have been machined smooth, they had a little grooving in the bottom sheave but had been smoothed out by rock river yamaha in johnson creek. Belt is sitting in sheaves properly. Only running Yamaha belts.
What is my issue? Why is it cooking belts.
poor farmer/logger
- Dec 3, 2012
- Saskatchewan
Have you read through the comments in my belt post? I'm not nearly as bad off as you but my belt life seems to be dropping off some. So far I haven't found any one thing jumping out at me and saying fix me. I'm thinking I'm my case it may just be a combination of a bunch of little things gradually getting worse.
sxvipersman
- Mar 19, 2006
- Dover Centre,ON Canada
- 2008 FX Nytro RTX Anniversary Edition
1979 Enticer 340
2009 FX Nytro XTX
Sounds like clutches are missing aligned in some manner, ie center to center or offset. I have ran the same belt for 3 years. With upgrades and no problems. I would definitely check it out. Long shot check motor mounts. Just my 2 cents. Good luck.
R00STER
- Mar 3, 2013
- Timmins, Ontario
- 2013 Nytro xtx 1.75
I was having the same issue a few years ago. I had clean clutches, aligned perfectly, washed new belts, everything else i could think of. Then I realized that the inner bushing on the secondary clutch was a bit worn down, so when the secondary was off the machine I could get the rear sheave to rock back and forth a bit on the front sheave instead of sliding in and out properly. My theory was that the secondary could bind under those conditions, so I changed out the bushings.
It worked for me, I have not blown a belt since.
Pmtg04
I think I heard about the skid plate missing or coming loose will allow snow to get on the clutches, causing slip, causing heat, and resulting in belt failure.
Hooray!
- Aug 12, 2017
- Maine USA
- 2009 Yamaha FX Nytro XTX
1998 Yamaha VMAX 700 XTC
1100 miles on my new yamaha belt this year... Zero signs of wear, looks new even on edges. Mis-alignment makes sense... Strange to see 100 miles per belt.
i would check clutch bushings 1st before going deeper.
- 32K
- 146K
