SKIP
Wondering how effective the marginal wheel kits (front of rail & rear) will be with the 135mm wheel mod.  I assume these kits are designed for the stock 130mm wheel right?
Is there a wheel kit available with a larger wheel (to match the 135mm)?
I have had good luck with hyfax wear in the past with the original idlers (3500 miles 1st set), but changed to the 135mm idler set up this year since I went to a fully clipped track. Last weekend I went thru the hyfax to the rail, and now want to install a kit for the front as a minimum.
Cheers
Cheers
apltx08
You will notice more HEAT/WEAR with a FULLY clipped & opened window track in maginal snow conditions than a CLOSED window clipped every 3rd...my Bud opened and clipped his last year and I kept mine closed and noticed it a few times in marginal conditions he tends to HEAT up quicker, in normal conditions with snow dust no difference but in WET STICKY snow on milder days he's fine and I tend to heat up...he also gained TOP END speed.
